removing spark plugs???
hey, this his alarum's g.f, as you may know, i just got a 95 ex coupe, going to paint the valve cover tonight, wondering how to remove spark plugs?? i would ask me b/f, but he's at work.. please help.
RE: removing spark plugs???
im pretty sure you can just pull 'em out?
get a 5/8 socket---6 inch extention--& a ratchet ---assemble it --then stick it down the spark plug hole & turn counter clockwise
ORIGINAL: AOL.COM get a 5/8 socket---6 inch extention--& a ratchet ---assemble it --then stick it down the spark plug hole & turn counter clockwise |
You don't have to remove them. Just pull the wires off and you'll be fine.
Or you could use a spark plug socket, an extension, and ratchet. Wats the rubber hose for?
ORIGINAL: AgentofDarkness Or you could use a spark plug socket, an extension, and ratchet. Wats the rubber hose for? |
ya im sure dont have to remove them...just unplug the wires
u can also jus put some electical tape inside the socket that will work to that way they will come out with the socket... rubber hose is a good idea 2
Or you can just put lateral pressure on the socket/extension while you're pulling it out.
