Rockers
So my buddy says I need to adjust my rockers because that is what is causing the clackety clack in my engine :) Is this something relatively easy... before I go in there with a socket and start tightening - and breaking stuff?
RE: Rockers
It might be your valves ticking. I just had mine adjusted at the dealer ship. Made a big difference.
http://www.denlorstools.com/home/dt1...honda_car.html |
RE: Rockers
Yeehaw!!! I think your right 2slo4u, from the picture and the explanation on that site. I'll look into it. Thanks.
RE: Rockers
You can also do it yourself if you have a feeler gauge. Take the valve cover off, undo the nuts on the adjusters, then adjust them so you have .006 exhaust and .010 intake if I remember. Make sure those are the right numbers though. Tighten the bolts back up and put the valve cover back on.
Or you could always have someone else do it. |
RE: Rockers
thanks man, yeah, the problem I was having is finding the right gap setting - no manual to my car :( But even if those # are close it will be good because they are rattlin' loud, and i can physically move the arms a bit. Thanks again.
RE: Rockers
Hahah that's what it was like when I put my cam in. They were so unadjusted that you could of put a penny to two pennys in between them. I'm pretty sure those numbers are right, but I'll take a look tomorrow when I can get to my Hatch cause it has a manual in it.
RE: Rockers
if i can recall the intake side is always smaller thickness than the exhaust.
as in .006intake and .010 exhaust.. for example |
RE: Rockers
Your right. I checked today and it's Intake: 0.007-0.009 Exhaust: 0.009-0.011. Sorry about the mix up!
RE: Rockers
Just for anyone's future reference, it should say under your hood, too. I'd always go with those numbers unless you've changed engines or hoods.
RE: Rockers
Huh.. I didn't know that. New knowledge for me! Whoo!!
