rod knock? NO compression
how do i fix the rod knock and i know i need a new head gasket but what are some other factors, is that the only thing that i would have to replace in order to compression back to normal?????
RE: rod knock? NO compression
alot....
like all the rotating assemblies bearings, prolly rebalence the crank and rotating assembly if it got hot and warped at all. |
