Seeing how this sounds to people.....help is greatly appreciated
Old Jul 13, 2007 | 06:33 PM
classiccarsrule85's Avatar
Default Seeing how this sounds to people.....help is greatly appreciated
Ok so let me see if this sounds ok to you guys im possibly going for a dohc motor swap into my '95 Civic vx with a z6 in it, first off I can pick up a b18a1 motor came running out of a integra with 160k on the clock no wire harness or computer or trans pretty much the motor and anything that was attatched to the motor such as alternator and distributor etc......for about 100$'s im going to try to talk them down to 75$ but i think still this is good for me......I also came across a B16 vtec trans hydraulic which i need, for 375$....Wondering if this will work ok with the engine i am getting im pretty certain that all B-series trans will bolt in or at least thats from what i read. So far I have a engine and trans and am going to need a wire harness for a b18a1? and a ECU I am not sure of OBD's and which one i should get im guessing OBD1 ? might i need motor mounts ive read a couple times that it is a direct bolt in but that is with a straight ls swap I am using a b16 vtec trans ...same thing possibly? ........And will i need different half shafts? and if i do will i need different part for where the half shaft connects to the wheel hub(cannot think of the name right now) or will it be ok ? And the most important question of all am i missing anything ? since it would be very bad for me if i sell my motor swap and not be able to put this swap in ..........If the prices sound ok please let me know.
Kinda off topic on what i was going for here but I am wondering as well how much d16z6 full swaps go for usually? since in order to get the money for the parts i will need to sell my engine......
Thank you very much for helping me I know there are plenty of things out there but I cannot find them.......
John
Old Jul 14, 2007 | 07:25 AM
Default RE: Seeing how this sounds to people.....help is greatly appreciated
anyones?
Old Jul 15, 2007 | 07:50 PM
seriously no one wants to help me out here just some simple questions.....
DoctorHorrible
Oct 16, 2011 10:18 AM
crazybolts
Dec 29, 2007 11:06 AM
lacivic
Apr 25, 2006 04:37 PM
