Shifting
I was watching my buddy race his 99 honda ex, (sitting in passgener seat), he was shifting in the red rpm range. he thinks thats the best way to race a 5spd is to let the rpm reach the red zone. how can I convince him that it ruins the engine or tranny.I believe the best way is to (in a race of course) shift is right before the red zone. Who is right here.
I don't even watch the tach. Get to know your car. When it stops pulling- shift.
But if you need something to tell your buddy... tell him that his car makes peak Hp @ 6600 rpm so what's the point of him going beyond that?
wow your the new sacions (your like superman), hows the supercharger going, how much did cost. did you have to make any upgrades in order to install it, does it have any bad sideeffects on the engine. i am going to shutup now
I am faaaaaaaaarrrrrr from Sacicons. You and I just happen to be on at the same time every day, which isn't too tough because I am on at least 8 hours a day. But I have learned enough on here to answer a Q. every now and then.
The supercharger is going Ok. I got about half of it done today before work. The beauty of the Jackson set-up is that you don't have to upgrade your internals with the stock kit. You dont' even need I/H/E because they have tested like every component in the universe and found no (or nominal) gains with them. Not even a cam. How's that for "bolt-on" power? The other thing is that there is a bypass valve on it so when you aren't hard on the gas... no boost and no extra wear on the motor, but I imagine as with any serious upgrade it has to shorten the life some, but how many turbos do you see with a 100,000 mile warranty?
Check out their FAQ's. I read them like 30 times while I was waiting on mine.
Jackson Racing's FAQ's
ORIGINAL: Street Sniper
