SHOULD I GO FROM STOCK TO LS 1.8
Old 06-18-2007, 11:07 AM
Default SHOULD I GO FROM STOCK TO LS 1.8
I have a 94 honda civic withstock v tech, I blew the motor and came across a Acura LS 1.8 DOHC motor.My problem is, its not a V tech. But I am getting for $1500. installed. and it has low miles. Would it be worth it, and what kind of performance can I get out of it.
Old 06-18-2007, 02:11 PM
Default RE: SHOULD I GO FROM STOCK TO LS 1.8
it'd be faster then a sohc. and you can always swap the head on it
Old 06-18-2007, 04:36 PM
^ +1.Swap the head and you'llhave a good platform to work off of.
and it's V-TECnot v-tach
Old 06-18-2007, 07:47 PM
i'de put that down the road a while. i'de get the motor init first
Old 06-18-2007, 09:06 PM
riceburner700's Avatar
its not a bad idea if you could find a dohc vtec swap that in since you are already wired in for vtec, but the ls is a very good platform to work with, just slap in the harness and computer and away you go
Old 06-19-2007, 03:24 PM
IfI do put in the 1.8 DOHC do I need to change the clutch and tranny or will mine work? Its a stage2 clutch with a stock trannyand I really dont want towaste it because its new. My stock motor is aSingle cam V tech, does that affect it. AndIs ittrue that its harder to put a turbo on a DOHC V tech than a non v tech?
Old 06-19-2007, 04:55 PM
you need a b-series trans. none of the SOHC stuff will bolt up.
DOHC vtec and non vtec are almost identical. minus some things. but no its the same to turbo either or
sureyoucan
10-28-2008 11:36 AM
Steven T
12-07-2007 10:57 PM
cowsgonemadd3
09-13-2007 04:28 PM
Marty
03-25-2006 09:34 AM
Quick Reply: SHOULD I GO FROM STOCK TO LS 1.8
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
