si si racing head
hey guys ! does anyone know where i might be able to get a hold of a new racing head for my 99 si ?? thanks for ur help ! just so we r not confused ! (not header ) the head ) :) :) thanks
RE: si si racing head
Port, polish, and cams and you have your own....;)
ORIGINAL: ntxmotorsports Port, polish, and cams and you have your own....;) The cheapest route would be to go with Skunk2 stage two cams, retainers, valve springs, etc... right around 1400. Then a port and polish. Or you could TRY to find an integra type R head. Same head as on the b16, just more agressive cams, and it breathes better. (among a few other smallish details) your best bet is what ntx said. |
ORIGINAL: 2000Si :thumbsup: Same head as on the b16, just more agressive cams, and it breathes better. (among a few other smallish details) your best bet is what ntx said. |
the type r head also has dual valve springs on both the intake and exhaust sides, as well as lighter valves and retainers. thats why it can rev higher than the b16a head. not a bad upgrade, but they are pretty expensive. also remember that you will also have the stock head to sell.
ORIGINAL: sacicons the type r head also has dual valve springs on both the intake and exhaust sides, as well as lighter valves and retainers. thats why it can rev higher than the b16a head. not a bad upgrade, but they are pretty expensive. also remember that you will also have the stock head to sell. |
have fun. reving a stock b16a to 8500 will float the valves and toast the motor. you might get away with it for a while, but not long. you'd better upgrade the valve springs first.
to answer your Q, SI_Racer, what are your power goals with the new head? Budget?
ORIGINAL: sacicons have fun. reving a stock b16a to 8500 will float the valves and toast the motor. you might get away with it for a while, but not long. you'd better upgrade the valve springs first. |
but do the stock cams even produce power at that high of an rpm? ive never seen the dyno plots of the stock b16 cams but im sure it doesnt produce much power that high. ive got the cam specs somewhere for all b series vtec heads......somewhere.
