Skunk 2 or Type R?
Old May 17, 2006 | 09:36 PM
sillyredcivic's Avatar
Default Skunk 2 or Type R?
I am redoing the internals on my B16 and have come across a dillema. Do I go with the Skunk 2 Stage 2 cams or JDM Type R's? I can get both readily, and brand new in the box. whichever way I go. Has any body else gone with either of these cams? I could use some sound advice as to what the general opinion is. I will be doing valves springs, and retainers at the same time along with a block girdle, and port and polish. Also should I go with the oversized valves or stay stock sized?
Old May 17, 2006 | 09:40 PM
Nail I3unny's Avatar
Default RE: Skunk 2 or Type R?
what are your plans for the car?
Old May 17, 2006 | 10:11 PM
Well as much as I want to say turbo, I think I'm heading down the N/A path in course. I use the car everyday so reliability is mandatory. I have done the all the fuel upgrades being fuelpump, regulator and fuel rail. Next will be injectors.
Old May 17, 2006 | 10:26 PM
riceburner700's Avatar
i would say oversized since you are there like .5 to 1 bigger
Old May 18, 2006 | 04:24 PM
dont get type Rs if you wanna boost. too much overlap. get some good Skunk2 turbo cams. or if you wanna go through the trouble, you can get a GSR intake and ITR exhaust for a sweet OEM setup.
Old May 18, 2006 | 04:34 PM
TFC_Bob's Avatar
I would go Skunk 2, especially if you plan to turbo later, after all the Type R is only stock and even though its rated as the best by honda oe standards
Old May 19, 2006 | 10:10 AM
the right combo of type r cams will hold with skunk2 easy. skunk2 turbo cams arent the best thing out there and OEM parts can hold.
funkytaha
Jul 16, 2009 11:05 AM
Ghetto2315
Jul 13, 2008 03:18 PM
Fiirkan
Sep 21, 2007 04:32 PM
krzemienr
Dec 7, 2006 01:30 PM
blkcivicman05
Apr 29, 2005 10:37 PM
