So at what point...
So at what point...
At what stage of N/A builds will the fuel mileage go down?
From what I can guess, once you move to a larger injector or increase compression you're going to start loosing fuel efficiency, also if you hog out the head a lot. Any thoughts?
On the other hand, I/H/E, mild head porting, or a cam shouldn't effect it from what I can tell... but increasing compression is causing more resisitance to the rotation of the crank, and typically larger injectors don't atomize as well.
knfdeals
02-20-2007 01:19 PM
knfdeals
02-19-2007 07:44 PM
