Spending Money Wisely....
If you had a honda civic with a d15b and $5,000 to preform upgrades for performance only without swaping out the engine what modifacations would you make? But if you would choose to swap out the engines deduct that from the$5,000.
List all prices beside each upgrade. |
RE: Spending Money Wisely....
turbo kit pieced together 800-1500 dollars
hondata - 600 good tune - priceless |
hehe good tune priceless.
You also have to consider the labor costs if you decide to get the engine swap. |
Lets see if this one will work.
B18B1-$600 Rebuild Engine- $1500 Turbo Kit- $1500 ECU - 600 Other stuff - $1000 Total: $5200 Its a little over budget but not much. Labor not included and i prolly left out some stuff. |
ORIGINAL: AgentofDarkness Lets see if this one will work. B18B1-$600 Rebuild Engine- $1500 Turbo Kit- $1500 ECU - 600 Other stuff - $1000 Total: $5200 Its a little over budget but not much. Labor not included and i prolly left out some stuff. |
$2,100 plus S&H I am guessing around $300 170 HP
B16A G2 Engine ECU (P30) 5 speed LSD transmission Distributor Intake Manifold Exhaust Manifold Injectors Starter Alternator JDM Wiring harness OBD1 Power Steering Pump Half Shaft/Intermediate Shaft A/C Compressor Throttle Body Fuel Rail Down pipe Sensors 50 HP dry kit NOS $550 Add about $1000 to that just for install and other little parts that might be missing I would spend the rest on a traction bar $350 11” brake kit that uses my stock calipers $350 Sway bars front and back $250 = a grand total of $4900 |
