Starting A build please help
there you were corrected lol, 1 hp off
D16Z6
D16Z6
- Found in
- 1992-1995 Honda Civic Si
- 1992-1995 Honda Civic EX, EX-V
- 1992-1995 Honda Civic ESi (European Market)
- 1993-1995 Honda Del Sol Si (US)
- 1993-1995 Honda Del Sol ESi (European)
- Displacement : 1,590 cc (97 cu in)
- Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
- Rod Length : 137MM
- Rod/Stroke : 1.52
- Compression : 9.2:1
- Power : 125 hp (93.2 kW, 127 ps) @ 6600 rpm
- Torque : 106 ft·lb (14.7 kg/m, 144 Nm) @ 5200 rpm
- Piston Code : P28
- Volumetric Efficiency : 87.68%
- Redline : 7500 rpm
- Fuel Cut : 7411 rpm
- VTEC Switchover : 5500 rpm[2]
- Fuel Control : OBD-1 MPFI
- Head Code : P08
- ECU Code : P28
yea like that, you will also need a few other things to make it fit into your civic, also need a b" series trans. but a great start. i have a some what built b16 and vtec kicks in at 5200 rpms and pulls til it redlines at 9k. where as your d15 motor redlines at like 5500-6k rpms. the b18 block will give ya the torque and the b16 head will give ya the top end. just look around you may find something in craigs list.
turbo speeder
Jan 28, 2009 03:57 PM
SovXietday
Feb 12, 2007 11:55 PM
