STeps I should take to Spraypaint my Valve Cover
RE: STeps I should take to Spraypaint my Valve Cover
Take the valve cover off or tape the area around it off in your engine bay(I suggest taking it off)
Clean the comnplete valve cover with a product like simple green thuroughly.
Let it dry completely.
Sand it with a high grit sand paper like a 2000 grit, Then go to 1000 grit, then 500 grit, and keep going untill you get a desired smoothness.
Primer it.
Apply paint, remember that the more coats you do the more depth it will have. After you apply like 2/3 coats wet sand it with a high grit sand paper like 1000 grit then re-apply how ever many coats you want(8 to 10)
Apply a clear coat, again the more coats you apply the more luster and shine it will have. Let dry completely then buff it.
Primer it.
burgernuds
12-22-2008 10:50 PM
liltlew
02-18-2008 09:48 PM
mill$civic
10-31-2005 06:25 PM
