swap help
i have a 95 civic ex with an auto d16z6 and i have a b18c1 complete engine and i was wondering what all is needed to do the swap and what is need for an auto to manual swap. How much could i get for the d16 with 96,000 miles. any help would be nice
the biggest problem is going to be the clutch pedal etc. but very doable. what year is the motor? and what parts do you have with it? did you get the ecu with it? also you will have to do some vtec wiring, but really you didnt supply qute enough info..
hey well i just got an auto to manual swap done. things you need, the pedal assembly(i found mine on ebay), shift linkage and axels, a mount to mount the manual transmission to the auto chasis (www.hasport.com), a clutch line(www.horsepowerfreaks.com), shift boot and ****, and the hardest thing to find is the line that goes from the clutch master cylinder to the slave cylinder. its called like a hard line or sumtin, i found mine again on ebay.
hydro_yang
Sep 12, 2009 01:18 PM
silvr63vet
Dec 4, 2006 03:55 PM
