Swap Question...Which one would be better?
Plan on swapping a engine in a 95 Civic EX......Just don't know the route to go.
Plan 1
B18B with GSR tranny
Plan 2
B20B with GSR tranny
Is this possible and what parts would I need (engine, tranny of course...but what else)? and how much work is it going to be? If I go with Plan 1, in the future, I plan on doing a LS/Vtec engine.
Thanks in advance
Plan 1
Plan 2
Thanks in advance
RE: Swap Question...Which one would be better?
B18B1: 142hp @ 6300 rpm & 127 ft·lbf @ 5200 rpm
B20B: [*]Power: 126hp @ 5500rpm[*]Torque: 133 ft @ 4200 rpm
both Non-VTEC....any reason you're picking non-VTEC engines? B16a2 swaps are fairly common....
the b20b is the lower compression of the b20's theres the jdm b20z that has a 10.0:1 compression.
do yourself a favor and put a set of ARP rod bolts in and do the conversion to use a B16 head and go CRVtec
"any reason you're picking non-VTEC engines? B16a2 swaps are fairly common"
no reason just not really looking to spent to much money on the engine, which ever engine i go with will get the usual stuff like I/H/E, fuel system, clutch....yada yada yada...just the simple stuff, but i mean down the road i do want to boost it and maybe go with a vtec head... and i dont wanna b common haha
but either engine i go with the gsr tranny would be good to go? which tranny should i go with s80 or y80 whatever other ones there are.
im still really new to this stuff and i try to do a lot of research before i get into this stuff but any good info from experienced swappers would be greatly appreciated...
any good websites for jdm engines?
thanks again
thanks again
ORIGINAL: Ajdin85
its cool, i'm still learning ALOT too
but usually the only time you need to mess with your fuel system/how much fuel your putting into your engine is with some kind of F/I (turbo/supercharger) because of all the added air coming into the engine, you need fuel to match it.
thanksfor the info Flip,i learn something new every day
now what do you think should i go with B18 or the B20
and where could i find the b20z....i wanna look at the price for that
