throttle body spacer
http://www.car-stuff.com/includes/se...B3YXJyYW50eS4=
So i call bs on this.. want opinions on if u think this is true or not.. do you think this is worth buying $88 Honda Civic Throttle Body Spacer - Top Sellers Product Description Zoom Street Performance Throttle Body Spacer - Helix Power Tower Plus - Aluminum, Direct FIT Product 2001-2004 Honda Civic STREET PERFORMANCE HELIX POWER TOWER PLUS THROTTLE BODY SPACER, T-6061 ALUMINUM -- Provides additional power up to 22 h.p. and 25 lb.-ft. of torque and improves fuel efficiency up to 4 miles per gallon; Includes gasket, bolts, spacers, washers, and vacuum hoses; Crafted from precision-machined T-6061 aircraft solid-billet aluminum for long lasting performance; Engineered to provide increased air-flow and performance throughout the power band; Features computer-designed chambers and channels to improve air velocity performance; Its variable venturi aperture provides turbulence to mix the air and fuel charge for a complete burn efficiency; Can be used with any grade of fuel; Easy installation; With Street Performance's 30-day warranty. |
Throttle body spacers do absolutely nothing. I wouldn't waste $8 on one, much less $88.
22hp says it all
that reminds me off the tornado bs they came out with that goes into your intake
