timing belt change questions
I am planning on changing my timing belt and water pump, but i dont have one of those pulley wrenches, and looking on ebay the cheapest one is 32 dollars.
I dont care about changing the other belts, so will i definitely have to remove the pulleys in order to install the timing belt and water pump, or can I just loosen them to move the belts out of the way? Also, Im pretty sure my timing is off right now by a couple teeth, would I have to use the timing gun to set it before i do the change, or will putting the wheels at TDC fix that problem? Im pretty nervous about doing it myself even though i ordered the chilton's manual. how many hours of labor would a garage charge for it? |
for a price for a shop idk you would have to call and ask,
but i say you can do it, its not a hard job, and the markings are visable, putting the timing marks tdc will fix ya up, it will run better and start faster when ya get a new belt and its on time. you can download the manual instead of buying it, if you have the tools and have a common since about engines you can have it done it about 2-3 hrs. just make sure your timing marks are dead on, and also your belt is tight and the tensioner is tight. if you have any ?????'s just let me know |
will i definately need this tool? or could i manage without it?
http://cgi.ebay.com/ebaymotors/Honda...motiveQ5fTools thanks for all the help, still waiting on parts to get here next week, i will let you know how it goes when im done |
i would get it
actually after u use it ill buy it off u i spent 2 hrs trying to get mine off without a tool then i got a giant impact gun like looked like a jackhammer big took it off in 2 seconds |
