Timing Belt Kit, Anygood? 01 EX
Having the timing belt done shortly. Saw an interesting kit on Amazon for $150 shipped for my 01 Civic EX. 136K miles but unable to verify if the timing belt has ever been done. I've heard of some of the brands, what do you think?
Amazon.com: Timing Belt Kit Honda Civic 2001 to 2005 1.7 LX DX EX: Automotive Here are the components included: Timing Belt Kit Honda Civic 1.7 LX DX EX 2001-2005. Includes: * timing belt * water pump with gasket * timing belt tensioner * timing belt tensioner spring * both accessory drive belts * valve cover gasket set including grommets and spark plug tube seals * front crankshaft seal * front camshaft seal * timing belt tensioner bolt. Featuring products by Bando, Contitech, Mitsuboshi, GMB, Koyo, NTN, NSK, NPW, Paraut, Aisin. This kit will service Honda Civic's with (1.7L) D17A1 or D17A2 engines with a year range of 2001-2005. Services years: 2001, 2002, 2003, 2004, 2005. |
With stuff like a timing belt (if it breaks, you probably just destroyed your motor), I would suggest to stick with Honda parts. I am sure the link you posted will be fine. However, if it were my car, I would be uneasy about it.
