timing belt and water pump
hey guys, my bud has a 94 integra....just installed a timing belt and water pump...the engine turned on normal and ran for about 5 min. Suddenly, it shut off by itself, and would not start again...wat happened???
when we try to start it again, looking through the oil cap, the Cams are spinining; battery is good...the mechanic told me there s no spark to the sparkplugs!!! it s been 2 days guys. someone help!!!! we dont know wat to do...[X(][:@]:(:(:(:( [IMG]local://upfiles/11910/7A333277EFB74D95A0866270148555D0.jpg[/IMG] |
RE: timing belt and water pump
1.check if the belt is tight. probably the tensioner somehow got loose.
2.make sure the timing mark is @TDC. maybe it skipped a tooth or two |
i think the mechanic checked those.. even if number 1 and 2 happended, the cams should be rolling right?
damn you guys got oil on alot of things.... lol timing belt looks kicka$$ is that a stronger one than oem?
100 buck ebay greddy timing belt... :( cant start.....
