Timing Question
I have a question can i use a timing light to time my D15
I cant find a timing mark to go by so i'm kinda doubting it I'm gonna miss the ease of timing the domestics sbc's are so easy |
RE: Timing Question
1 Attachment(s)
yes, you can time it with a timing light. on the crank pulley there should be 5 marks. the mark in the middle of the group of three is the setting you want to set it to. line that mark up with the v in the belt cover and another tab in the timing cover
Attachment 41323 |
RE: Timing Question
How in the world did you get that pic? I tried like 57 times and I couldn't get one.
Btw- What would you say the timing in that pic is? 8-9* btdc? Or is it just a parallax view? |
RE: Timing Question
the car wasnt running and the angle is a little off to get an acurate reading on the timing
RE: Timing Question
I really hope you're not talking about not knowing where the TB marks are, because if you put it on a tooth or two off, then try to run the car, the only thing you're going to get is bent valves.
RE: Timing Question
ORIGINAL: Kappa22 I really hope you're not talking about not knowing where the TB marks are, because if you put it on a tooth or two off, then try to run the car, the only thing you're going to get is bent valves. |
