is the tranny shot?
when i picked it up the auto trans in my my new 02 ex was slipping a little. the fluid was brown, burnt, varnish, etc. for only 30k mi this fluid looked like it had 100k on it. what general inspection procedures could tell if there is any damage? if it still slips after a fluid change do those trans additives work to prevent such slippage? anything else helps.
thanks |
RE: is the tranny shot?
ORIGINAL: induction1 when i picked it up the auto trans in my my new 02 ex was slipping a little. the fluid was brown, burnt, varnish, etc. for only 30k mi this fluid looked like it had 100k on it. what general inspection procedures could tell if there is any damage? if it still slips after a fluid change do those trans additives work to prevent such slippage? anything else helps. thanks First - place a very strong flat magnet on the bottom of the tranny pan (some people like to put them inside the pan, but import tranny pans usually do not have a lot of room from the bottom of the pan and the valve body of the tranny) This will help keep the everyday wear and tear metal shaving from circulating through the tranny. Second - install and good tranny cooler on the car. Auto trannys cool there fluid by running it through a tube in the radiator. Well just how well can hot water cool? Trust me, by installing a T/cooler you will add years to the life of your tranny. |
Hey man maybe you can help me out here i have a honda civic hb 91' and i just bought a 5 speed tranny from a 88 civic si and i tried to replace the 91 tranny with the 88 tranny to convert it to a 5 speed. well it wouldnt fit because 91 clutch is different the guy i bought it from said that i had to just get a 88 clutch and it'll fit fine. is that true? should i put the 88 clutch in the 88 tranny and put it into the 91 engine or should i just sell the tranny ? please help me!!!
yeah, it should work as long as you get the clutch that matches the trans, and the flywheel and pressure plate that match the engine. i think the only difference is the input shaft, so it should be fine.
