trying to find a valve cover breather!
I need help finding a valve cover breather kind of like this one:
http://usera.imagecave.com/95civic/R...ht_eg_02_z.jpg |
RE: trying to find a valve cover breather!
are you talking about the oil catch can? you can get a breather filter at autozone
no it is a valve cover breather. you no like the line that hooks up from the valve cover to the air intake? well if you have a turbo most people buy valve cover breathers.
Take a look again and see were the breather hose goes to. http://usera.imagecave.com/95civic/C...ht_eg_02_z.jpg |
look up an oil catch can, that is what it is, under high rpm, the oil will get into the air intake from the breather line, and cause your engine to smoke. http://www.optionsauto.com/prodinfo....ber=CUS-307009
that one you show has a breather filter attached to the top. |
i want one with a breather filter on it.
just go to autozone, they're like 10 bucks
are you talking about the steel-braided vacuume line?
No a breather tank for the valve cover
why do you need a breather so bad? the tank will be vented to prevent pressure buildup in the engine
