turbo boost and fuel pressure!!!
Ijust got rid of a mustang that i built into a stroker and decided to try out at imports. On a stock 97 hond civic, how much boost would it be safe to push with added fuel managment upgrades. Also what size injectors would be best, and what should i set the fuel pressure regulator too. Thanks.
RE: turbo boost and fuel pressure!!!
Stock engine can safely handle 200-220 whp. First and foremost,run a compression test on the car.....if all the cylinders are 10% within eachother, youre good to boost. Youll need like 450cc injectors, and a chipped ECU, tuned with chrome, neptune, uberdata or run hondata. 220whp is typically good for 13 second passes..........and 35+mpg.
