Turbo charge or Swap?
I was wandering i have 2000 civic Dx would it be better to turbo charge the SOHC engine or do a engine swap to the B16 in the 2000 Si?
RE: Turbo charge or Swap?
depends entirely on your goals for the car.
The B16 isn't the best engine for boost because it has high compression.
I want the car to be reliable if i turbo charge the d16 can i get 200 whp or just swap to the B16 from 2000 Si and remain NA
Turbo.
I want the car to remain reliable if i turbo charge and run low boost will it be reliable cause i need my car to get around its a daily driver.
Sure. In fact a turbo would increase your highway fuel mileage if you tune it correctly.
ORIGINAL: pWnEdU Sure. In fact a turbo would increase your highway fuel mileage if you tune it correctly. |
GSR ftw
you said a GSR swap would be reliable for daily driving?
