turbo D, questions and opinions
Old Jun 4, 2006 | 07:01 PM
emooheo's Avatar
Default turbo D, questions and opinions
im gonna be turboing my D in a couple months
My goal = 300 hp
plan:
forged pistons, not sure if i want 9.0 or 9.5:1 compression, opinion? what brand do u recommend
eagle connecting rods
block guard
2.5" exhaust
450cc injectors
turbo:
i'm thinking about greddy kit, with an ebay intercooler and manual boost controller, upping boost to 15 psi. using e-manage that comes with kit
or
everybody is saying to build my own kit, i have no experience with welding and know nobody that can do it, would it still be a smarter plan? depending on how much the kit came out to, id run hondata s200 w/ boost, or the hack
what would you do? what would be a good size turbo for my goal that will spool by 4500 rpm or less? im kinda on a budget, 3 g's max for everything, including dyno tuning (~$300), so ~2700 for the goods.
thanks
Old Jun 4, 2006 | 07:10 PM
riceburner700's Avatar
Default RE: turbo D, questions and opinions
i know im running a t3 and its spooled by 4000... i would say a t3/t4
Old Jun 4, 2006 | 10:46 PM
Pete's Avatar
9-0 compression. Eagle H Beam Rods. SRP Pistons. RC550 injectors. Electronic boost controller. Stock D block can take 350 hp. Blockguard is not needed.
Old Jun 5, 2006 | 12:01 AM
AgentofDarkness's Avatar
Get a 100 shot of nitrous and you'll be golden (not sure if you need sleeves for 400HP). Since you will only use the nitrous at the track, it won't beat the crap out of your motor all the time and the sleeves will make the block stronger. Also, you can offset some of the turbo lag by using the nitrous. Just an idea.
Old Jun 5, 2006 | 01:58 AM
emooheo's Avatar
ORIGINAL: AgentofDarkness
well.. i would do that.. but thatd put me 2 g's over my budget atleast..
im going with a garrett t3/t4 turbo
for pistons i have found 75 and 75.5 for the d16z6 which would be better?
Old Jun 5, 2006 | 04:07 AM
Civic|UnLimiteD's Avatar
wouldent the turbo blow up your engine from only soo much induction being forced into your engine....i wonder if they have a special thing from preventing your engine being blown
Old Jun 5, 2006 | 08:37 PM
Nail I3unny's Avatar
JE pistons, eagle H beams (or carillo I's if you can find them), ARP headstuds. i'll back what pete said and say you dont need the blockguard. ive heard some bad things about them anyway
Old Jun 5, 2006 | 09:27 PM
Pete's Avatar
theyre more trouble than theyre worth......running high boost is going to make u wanna get an aluminum radiator and a lower temp opening thermostat,
Old Jun 5, 2006 | 10:11 PM
I've heard some not so good things about block guards.
Old Jun 5, 2006 | 11:19 PM
shopmanual's Avatar
What kind of manifold are you thinking?
WILMER007
Dec 24, 2008 11:46 PM
samsonslmpson
Aug 2, 2007 11:58 AM
oldguy
Mar 17, 2007 01:03 PM
soldout712
12
Oct 30, 2006 11:05 PM
Sleepin95CivicDX
Aug 2, 2006 11:49 PM
