Turned 100,000
My 2000 LX just turned over 100,000 miles and I've been reading around the forum that a new water pump and timing belt change is in order. I just had a mechanic quote what that would cost today and it was about $400. This isn't too bad, but he said a little over two hundred of that is in labor. I was just wondering, if I got a haynes manual and the parts, how hard would it be to do myself. I'm in high school and work a lot, so I have the money, but would rather not have to spend it. I'm mechanical and have worked on things before, so I don't think it would be too hard of a project to tackle. I would just like a little input on the difficulty. Thanks.
RE: Turned 100,000
do it yourself. nothing to it.
RE: Turned 100,000
Nothing to it=if you can get crank pully off :)
RE: Turned 100,000
DOOD. get yer butt to teh honda dealership and change that belt out or do it yourself!11
if that belt snaps on you, you'll be sitting inside a sooper expensive paper weight because honda engines are interference engines. ≈ that means that if your timing belt breaky, your valves come crashin' down into your piston headies... honda recommends changing the belt every 60,000 miles. besides, $400 for timing belt change is dirt cheap from a dealership. |
RE: Turned 100,000
ORIGINAL: drbyers honda recommends changing the belt every 60,000 miles. You can get the OEM belt itself online for about $30, and pump for about $70, by the way. |
RE: Turned 100,000
Yeah, I've read my maintenance log, and it says 105,000 and I've also read 100,000 on the forum and I already know what happens when that belt goes, so yes, I'm definately going to change it out very very soon. Thanks for all the help. I don't think I'm going to pay $400 to have it done though, I've been meaning to get a manual anyway, and besides, I can take a little more pride in saying I did it myself and did a good job, than, I worked how long to pay some guy to do the exact same thing.
