unfair treatment
Old Aug 8, 2006 | 05:50 PM
koots's Avatar
Default unfair treatment
if the oil wasn't changed in a D16 for about 13 months what kind of damage am i looking at just based on this information. car sounds fine but hesitates off of idle for a millisecond
Old Aug 8, 2006 | 05:52 PM
pWnEdU's Avatar
Default RE: unfair treatment
That's bad juju. How many miles in that 13 months?
I would change it right away, run some sea foam through it, and then do a compression test. That would be your best bet.
Old Aug 9, 2006 | 05:21 AM
koots's Avatar
the speedo was intermittent during this time and did not fully register all the kms. (canada) but the owner guesses around 300,000.
Old Aug 9, 2006 | 08:40 AM
ORIGINAL: koots
[sm=yikesomg.gif]
That's like 186,000 miles on NO oil change?!? You need to run a compression test immediately. It's really easy, pm me if you need any help
Old Aug 9, 2006 | 10:38 AM
koots's Avatar
NO the odo should read around 300,000 in general. he thinks it was about 80-100,000 without, but still it is cause for concern. i did the basic check of running the engine with the oil cap off to detect blow by through the piston rings and detected no more than other high compression 4 cylinders. but a compression check is more definitive. what PSI should i be shooting for? and how much difference is allowed among cylinders before problems are evident?
Old Aug 9, 2006 | 04:40 PM
pWnEdU's Avatar
Holy ****.
Old Aug 9, 2006 | 05:48 PM
Nail I3unny's Avatar
you're compression will have gone down a ton. you will probably have to get your cylinders honed and your pistons might need replaced too.
Old Aug 10, 2006 | 11:05 AM
YOur compression numbers should be no more that 10 off of one another.
Mine was 204 199 200 199, which is pretty dang good. (D16y8 with 64k+ on the odo) Motors will vary..
Old Aug 10, 2006 | 04:27 PM
koots's Avatar
thanks. i just needed a ball park figure on honda engines. so used to chevy V8's that i am out of touch with everthing else. now i will conduct a test once it is back in my possesion. (getting ball joints replaced)
Old Aug 10, 2006 | 09:43 PM
riceburner700's Avatar
might be back to the shop getting a replacement motor^^^as soon as it comes out... depending on the damage
