Unorthodox Underdrive Pulley
There was a big write up in HCI (hot compacts and imports) magazine about this pulley kit. Other threads have said that these kits dont work as good and everything, but the article was claiming like 18 horsepower on a VTEC or turboed car, and only like 10 or so on N/A (still impressive though). Opinions/Experiecne with these? Anyone?
underdrive pulleys modify the "gear" ratio of the pulleys powering accesories like power steering, alternator, ac, etc. The positive results are greater horsepower across the band and fuel economy(provided you don't start hammering around town.) The negative effect will be less effective accessories, most importantly, the alternator won't provide as efficient charging as previously. This should be minor, unless you have 500hp(373000w) hyperbole stereo pulling the juice from the battery faster than the alternator can replenish it.
This per my father's advice... underdrive pulleys are common to SBC as Sport Compact.
the reduced weight is what you want, so ef you're saying this is a good thing then? And you could always get a cap for your audio system if you needed it.
yeah thats what the article said. Unless you have nitrous, VTEC, turbo, supercahrger, etc. you see as much of a difference. So you guys are saying spend my money on something else?
ORIGINAL: FlipHKD720
davidjcomeaux
Aug 12, 2008 07:57 PM
therickus
Feb 20, 2008 07:47 AM
Jezzro
Jul 10, 2006 09:47 PM
