valve question
Hey peeps. Is there a way to tell if ur valves are worn or bad or how to tell if u need to replace?
RE: valve question
You can do a wet compression test to see if they are sealing correctly or not.
RE: valve question
i have them outa the head. so is there anything visually i would need to know? aside from the massive carbon build up
RE: valve question
take them to a machine shop and ask them to see if there bent
RE: valve question
ok thanks ill try that
RE: valve question
u can lapp the valves to the valve seats so u know they are seating properly if none of them are bent.
