wat do i need to b18c4 cylinder head on a b 16a2 engine?
my timin belt snapped and i now left with a need for a new cylinder head! i have found a cylinder head but it's a b18c4 engine with fuel injection system and the injectors. wat else do i need to put the head on my engine?? need help asap
SAVE MY CIVIC |
RE: wat do i need to b18c4 cylinder head on a b 16a2 engine?
well it should be the same as the b16 head your going to lose compression tho. umm i suggest just switching the head not the injectors or anything because your gonna want to have the b16 intake manifold its the best intake manifold of all the b-series motor. make sure you replace the head gaskets and or needed gaskets good luck!
thanks will i need to change any other parts like the distributor or somat like that
the b16 one should work fine.
