What can I do??
What can I do??
I have a d15b7 in my hatch and am looking to just do what I can with it. anything just looking for ideas I want to get the most out of it. so far I have done the intake headers and pipe but now I want to start doing things that will give me a little more. anything would help thanx.
RE: What can I do??
i had the same dilema with my 95 dx coupe. if youre not looking to spend the money on a motor swap or FI, then look into a mini-me vtec head swap. you should be able to get everything you need for under 500 bucks. another option is to swap in the whole sohc vtec swap, with a d16z6, all you need is the motor with all attached accessories, your tranny will work but the z6 tranny has better gearing, and the ecu, then run a couple of wires. you should be able to find everything with a yahoo or google search
RE: What can I do??
ORIGINAL: sacicons
if youre not looking to spend the money on a motor swap or FI, then look into a mini-me vtec head swap. another option is to swap in the whole sohc vtec swap
RE: What can I do??
yeah, the immediate power gains are great with the DOHC, but the real worth of the b-series is in the potential power of the motors, you can build the hell out of a d16z6 and run the crap out of gsr swapped civics, but then they drop in a set of cams and a thin head gasket and theyll walk away from you. the best way to do it is to set up the suspension and brakes first, to handle the newfound power. i would have gone more in depth with my suspension and little stuff first, but a spun rod bearing required a new engine sooner than i planned.
civicxtreme
05-15-2006 08:11 PM
