what causes oil in the engine coolant?
what causes oil to gon in the engine coolant i noticed i was low on oil than wut i had put and i go to look at the puke tank and its all oily in there and grimey so i clean it out and again it happens and its only been 1000 miles any ideas?
RE: what causes oil in the engine coolant?
Cylinder leak
head gasket sometimes do it. but usually the other way round - water would go into the engine
yeah, its the head gasket. hopefully. if its not the head gasket, it could be a crack in the head or block:(, but im still betting its the gasket. these engines can take a beating before they crack.
Either a cracked block or the head gasket.
i was thinking it was the head gasket also it becuase the car doesnt leak any oil it just ends up in the coolant
Well, if it's the head gasket (which I'm also guessing it is) it's a pretty small seperation, because usually the pressure in the cooling system will force water into the cylinders, not oil into the coolant.
If you have oil in the coolant resivor its normally a blowen head gasket. Then again it could be a crack somewhere in the head. "[sm=laughat.gif]Did you also check your engine dipstick see if that to is all grimmey looking also?" That would be able to tell you something to.
[sm=laughat.gif] |
VTECH
ORIGINAL: importcivicus VTECH *Pcupo12 detains you.....cuffs you to a bench, where you shall await castration!* |
