What do I need?
Old Jul 3, 2007 | 07:19 PM
TIcivic00's Avatar
Default What do I need?
O.k. I have a 2000 civic ex with the d16y8 in it what would I need to swap it over to the si?
Old Jul 3, 2007 | 11:45 PM
Lost's Avatar
Default RE: What do I need?
to the 00 si? so thats a b16a2?
Old Jul 4, 2007 | 07:59 PM
jc6711's Avatar
ORIGINAL: Lost
yeah
Old Jul 5, 2007 | 04:24 AM
TIcivic00's Avatar
I was thinking more along the lines of a b16b
Old Jul 5, 2007 | 08:04 AM
jc6711's Avatar
it should be a basic swap in. i believe you are gonna need mounts a axels. the engine you buy should come with a tranny and shift linkage. and make shure it has a uncut harness.
Old Jul 5, 2007 | 08:26 AM
mxs's Avatar
mxs
the swap is fairly straightforward. you only need a couple mounts: Si rear tranny T-bracket, Si timing belt side mount, any 94-01 b-series front tranny bracket (if you want to use it), 96 Del Sol VTEC a/c bracket f you want to keep a/c, Si power steering pump if you want to keep that, b-series axles, b-series shift linkage. your engine harness will work but you will need to extend a few wires.
02civcoupe
Sep 17, 2006 08:29 PM
rx9790
Nov 1, 2005 05:53 PM
rx9790
Nov 1, 2005 05:52 PM
mcbride
EK Swaps
15
Sep 19, 2005 03:11 PM
