What do i need for a jdm d15b vtec swap..
I own a eg6 92 no vtec
whould the motor bolt right in????? Or wut elses do i nee:confused:d? |
4 Attachment(s)
yes it will bolt right up, but i suggest just getting a d16z6 head and putting it on your block, you will have vtec and more hp, all that is need to hook vtec up to work is you need the vtec head, and a p28 ecu there will be wires for the vtec, one is ground and the other 2 you run to the ecu,
i have some extra pins so you can wire it upto your ecu, this is where they go, i converted my eg to vtec, Attachment 15417 pin a4 is the vtec wire from the vtec solnoid, pin d6 is the oil pressure switch and i grounded the black wire coming from the oil pressure switch to the thermostat housing Attachment 15418 Attachment 15419 Attachment 15420 |
