what do i need for a mini me swap?
someone is parting out there civic and offered me a z6 head and asked me to make an offer and tell him wat i need. not sure wat z6 heads usually go for so not sure of a price to throw out. it will be picked up cuz he is in NY too. i was gonna ask for the intake mani and distributor. wat else should be asking for? and how much?
RE: what do i need for a mini me swap?
Required:
D16Z6 Cylinder Head (Including distributor cap, valve cover, plugs/wires, VTEC solenoid, etc) D16Z6 or D16Y8 Head Gasket P28 ECU D16Z6 Timing Belt Wire and plug for VTEC oil pressure switch Optional: D16Z6 Intake Manifold D16Z6 Exhaust Manifold *If you remove your manifolds, make sure you get new gaskets Recommended: NEW OEM- Water Pump (for the block you are using) Spark Plugs (HX D16Y5) Spark Plug Wires Valve Cover Gasket Distributor cap and rotor |
theres a DIY for it HERE https://www.hondacivicforum.com/m_45390/tm.htm
thanks for the link. was looking for it. didn't know it would be in drivetrain diy.
I have a 1.7vtec head intake fuel rail and a bunch of other **** for a conversion if interested?
