what engine?
do i have? and when it dies should i rebuild it or swap, and if swap. swap to what?
i have a 94 honda civic ex thanks |
92-95 1.6 L D16Z6 (Civic) EX/Si, Del Sol Si
Keep that engine rebuild it. then decide form there what you want, that is a great d engine.
619 FTW!! You should do a swap if you can afford it. Obviously do it yourself. Its fun that way. Why pay to wait. Go with any dohc vtech engine. Well again if you can afford it a b18c(thats jspec) or a cheaper alernative is the B18c1 either way. I know there's even better honda engines, I'm just being realistic since the dude lives in San Diego(the most expesive housing market to live in). If the above isn't an option you should boost the D you have. Its amazing how fast you can make the SOHC! Good Luck Kev 619
+1^ B18C5 1.8 16V DOHC VTEC PGM-FI 1797cc. 195hp@7800rpm. 130tq@7600rpm. '98-'01 Integra Type-R (JDM) Again that is if you can afford it. A diffrent d-swap would be cheap and prolly a little better than the one you have. D16y8a or something. then boost it. Definatly do it your self too. :-)
