What mod should i put under the hood????
So far i'm think cold air intake, header, exhaust system, and camshaft.... Anyone got anymore ideas without swapping engine or add nos or turbo???? Plus whats the best brand for it???
RE: What mod should i put under the hood????
by the way its a 94 Honda Civic EX. Right now it has 125hp and it would be nice getting it up to 200hp.
don't forget the fuel system.
underdrive pulleys, lightweight flywheel, hi-flow cat, and an ECU upgrade. The chip will probably cost the most but will make the biggest difference.
p&p head, high comp pistons, aftermarket rods, zex cam, zex valve springs, bisi header, skunk 2 intake mani, adj cam gear, msd 6al, external coil conversion for use with 6al, adj fuel press reg, 310cc injectors, teg tb, lightened flywheel, clutchmasters clutch, kazz lsd, underdrive pulleys. too many to list, what exactly are you going after?
hahaha.... and you thought you were almost done with your car.[sm=smiley2.gif]
Have fun! |
ORIGINAL: polo708 hahaha.... and you thought you were almost done with your car.[sm=smiley2.gif] Have fun! |
