what parts for N/A B16
Old Nov 27, 2007 | 07:45 AM
95civic1.6l's Avatar
Default what parts for N/A B16
I am thinking about getting a B16. What parts should i put in it if i want to run non-turbo? I want it to be reliable. Should i put internals on it? what should i get?
Old Nov 27, 2007 | 07:53 AM
cossie's Avatar
Default RE: what parts for N/A B16
Rebuild the engine wit ITR pistons and cams??
Old Nov 27, 2007 | 08:50 AM
Lost's Avatar
^ this guy knows it. Down the road you could also port and polish the head and get a good high flow header and intake and your ripping. Good header doenst mean DC.
Old Nov 27, 2007 | 08:55 AM
well since i am gonna swap the motor out. Haven't found the civic i want and i haven't picked up the motor but im looking into it for winter or spring. let me know if i need all this or if it is useless to put on. This is both bolt on and internal. intake manifold, throttle body, connecting rods, springs +retainers, camshaft, cam gears, plugs and wires, flywheel, clutch, tensioner pulley, idler pulley, valves, header,pistons. miss anything? do i need anything else? should i chip my ecu?
Old Nov 27, 2007 | 01:45 PM
riceburner700's Avatar
you will want a good flowing built head if your gonna be screaming up top everywere you go.
If you do anything to the head let me know. I will take good care of ya
Old Nov 27, 2007 | 06:32 PM
what do you mean screaming up top everywere i go??? i know you'll take care of me, don't worry. what else should i do to it?
Old Nov 27, 2007 | 07:09 PM
i ment the b16 makes all its power up top unless you stroke the motor out. The motors arnt a whole lot of fun under 5000rpm. With a nice flowing head the motor will really make MORE power up top and longer higher into its rev. I ment it as when you hit vtec and higher you will be glad you have a kicka$$ flowing head that the motor loves
Old Nov 27, 2007 | 07:14 PM
what did you have in mind? what kind of power would i be expecting?
Old Nov 27, 2007 | 07:17 PM
port/polish, supertech valvetrain, milling, valve seals, some N/A cams, good header, good intake manifold/TB, intake, high comp pistons, I-beam rods, good tune. you could hit probably 200-220whp depending on how its built
Old Nov 27, 2007 | 07:55 PM
how much would i be looking at spending for everything? Do you think i need all that stuff i mentioned b4. how much hp gain would i see from you doing work?
