What should the B16A2 cylinder compression be?
Hi,what compressionvalues should i expect to see with my B16A2? i know its ratio is 10.5:1, but what readings should i see for each of the cylinders?
RE: What should the B16A2 cylinder compression be?
160-180 i think is what it should be
Motors will vary, there really isn't a standard. As long as they're not ridiculously low (below 100) and are within 10% of each other, you're good to go
