HondaCivicForum.com
-   Engine & Internal (https://www.hondacivicforum.com/forum/engine-internal-11/)
-   -   Wireing harness question (https://www.hondacivicforum.com/forum/engine-internal-11/wireing-harness-question-61790/)
SpeedRacer_87 Mar 2, 2008 06:30 PM
If I swap in a B16A2 engine into my 95 civic ex can I use my existing wiring harness or do I have to get a new or different one?
The B16A2 is an OBD1 motor, what is a D16Z6?
drakkon Mar 2, 2008 06:53 PM
RE: Wireing harness question
i would suspect that you have to change the harnes, if you are going from a d series to a b series, as i had to modify my harnes just going from a d15b8 to a d15b7
SpeedRacer_87 Mar 3, 2008 11:52 PM
With swapping in a b16a2, is it pretty simple to just drop in? Does it use the same mounting points? How hard is it to change a wiring harness? And how long should it take to pull my motor out and drop in the new one? A week, a month?
drakkon Mar 4, 2008 08:37 AM
http://www.hondahookup.com/forums/sh...d.php?t=113747
