wiring problems with b16a in 93 civic.
i bought a 92-95 JDM b16a Gen2 (http://www.japanmotorimport.com/JDM_...16A%20G2_92-95)and im throwing it into a 93 civic HB. what do i need to make the wiring work with the ecu in terms of that whole obd1/2 stuff. should i replace the harness and ecu or buy one of those conversion adapters. i want it to be obd1 for tuning reasons. i also want to be able to hook up a APEXi VAFC once the motor is in.
Thanks - Dan |
RE: wiring problems with b16a in 93 civic.
Youre already OBD1 and you are throwing in an OBD1 engine. Am I missing something?
um i dont know.... my mechanic said there was an issue with the wiring.... maybe we're missing something. he said the motor is obd2?
it says on that site you listed that its obd1. the only way to convert it to obd 2 on a b16 is to swap out the oil pump for a 99-00 oil pump and put the Crankshaft position sensor in, put the obd2 dist on, and the obd2 computer in. i know this b/c i am in the process of putting it all in my 99 si with a obd1 GSR swap so i can get rid of it
