wtf is going on here
i finaly got my cel to go away and now my temp gauge stays at cold but my upper radi hose gets real hot so hot that i end up shuting the car for fear of engine failue oh and my fans dont cut on either
RE: wtf is going on here
Edited:
It sounds like you possibly may not be letting your engine heat up sufficiently to trigger the radiator fan to turn ON (circuit controlled by the TW sensor). If so, then you may only be having a problem with the temperature gauge circuit, which is instead controlled by the coolant temperature sending unit.
1) Let the engine run longer to determine whether the radiator fan eventually turns ON. If fan never turns ON, then check whether fuse #13 (under dash) or fuse #33 (under hood) is blown. Also, check whether the connectors at the TW sensor may be loose. Unplug and replug them to ensure that they are making good electrical contact. If the connectors are fine, troubleshoot the radiator fan circuit (fan, relay, TW sensor).
2) Temperature gauge problem: Check whether fuse #15 (under dash) is blown. Troubleshoot the temperature sending unit and gauge itself.
The picture shows how to test both the temperature gauge and the sending unit (the sending unit sensor appears to be located next to or near the TW sensor). Good luck with the troubleshooting.
[IMG]local://upfiles/25538/D740187697D04CE08D3B37E45D978947.jpg[/IMG]
Colby Day
09-25-2006 08:27 PM
blkwidow
07-27-2006 03:03 PM
