Y8 head on Y7 block?
Will a Vtec D16Y8 head bolt right onto a D16Y7 block?, I've always wanted to go Vtec since I got the car, but I want to know if the head of a Y8 will bolt right in, and if not, what's the proper procedure to get it all together.
RE: Y8 head on Y7 block?
There has beeb alot of mini me talk going on around the forum lately. It must be the big thing now. I know I am on the mini me band wagon.
Thanks for the link!, after reading all that I got one question though, What would be the correct timing belt to use for this mini-me, the Y8 belt?
your current belt is actually the same size as the y8 belt, tooth count and all. i used to be on the mini me bandwagon. nice thing about it is the sohc vtec cams are cheaper than non vtec sohc cams. although i prefer now to stay non vtec.
when you say the vtec heads, are you only talking about the piston heads? What about the actual v tec system? I have a D16Y7 - what kind of power gains in hp from changing to the heads you mentioned? Where can I get those from and what parts would I need specifically....
ORIGINAL: yaserkali when you say the vtec heads, are you only talking about the piston heads? What about the actual v tec system? I have a D16Y7 - what kind of power gains in hp from changing to the heads you mentioned? Where can I get those from and what parts would I need specifically.... |
ORIGINAL: HustlerX5 Thanks for the link!, after reading all that I got one question though, What would be the correct timing belt to use for this mini-me, the Y8 belt? |
OK....If I get D16Y8 cylinder heads, the vtec solenoid, wiring and an intake manifold from an EX - what are the power gains? approx? know any where I can get Y8 heads from? ANything else I need?
Y7- 106@6200 103@4600
Y8- 127@6600 107@5500 That would be the difference. Get the Y8 headgasket also. Parts can be had from local junkyards or ebay. Ebay will probably be cheaper. |
