Yay or Nay!?!?
Woot found my B18C1! I get the whole car(meaning plus chassis) but just that it was in a accident and the driver side doors are trashed, the engine is still good with no leaks btu with 115,000 miles on it.
Full swap: Year: 1998 GSR USDM Complete Engine Transmission ECU Engine Harness Shift Linkage Axels And Everything Else Price: $2,000 Mileage: 115,000 Yay or Nay? |
RE: Yay or Nay!?!?
Run a compression test on it and see if its worth a ****
RE: Yay or Nay!?!?
and if you can a leakdown
RE: Yay or Nay!?!?
compression test, but if you can get an entire B18 plus chassis for $2000 i say go for it, fix the doors up and you'd be good to go
RE: Yay or Nay!?!?
Finished
Compression tested from 245-250. I might jsut take the engine out and swap out my B16 if everyone thinks it's a good buy. Plus will the integra back rotors work for a drum->rotor back conversion? |
RE: Yay or Nay!?!?
ORIGINAL: ivtec Finished Compression tested from 245-250. I might jsut take the engine out and swap out my B16 if everyone thinks it's a good buy. Plus will the integra back rotors work for a drum->rotor back conversion? i think you need whole rear trailing arm assembly, plus brake lines, plus new master cylinder & proportioning valve other than that, if it passes compression & leakdown tests, snag it |
RE: Yay or Nay!?!?
I don't know what the average compression test for a 98 GSR should be but yeah I got
245 245 248 250 If anyone knows what it should be at please do tell, thanks. I am just worried 115,000 miles lol. And I should be able to get all those items for the back conversion on the teggy right? |
RE: Yay or Nay!?!?
numbers look nice and strong, and within 10% of each other...
i'd ask if they recently rebuilt the engine and/or head, or completely babied the car & motor nominal compression should be 270 I believe |
RE: Yay or Nay!?!?
Just asked the car was stored during winters and driven on mostly on weekends. No re-built and I rechecked the engine again with no leaks at all and all timing belt sounds really good.
RE: Yay or Nay!?!?
the belts should be changed at 100,000 so find out if they have been. and also dont worry about 115,000 miles, on a honda thats just broken in
