z6 or mini me?
Ok guys here's the situation. I have a perfect d16a6 block sitting in my garge, ready to be built from ground up, to a nice little mini me, but on the other hand a z6 would be easier....so I need some opinions. Anything will help. Thanks.
With a stock bottom end A6 and a Z6 head you will have slightly higher compression meaning more power vs the stock Z6 swap. So it's your choice. 9.95 to 1(pretty much 10 to 1) or 9.1 to 1.
higher compression ratio asin a smallerspace for the gas to blow up in your cyl. Smaller place for the same amount of gas to explode in(also called combustion) the more force it will push the piston with. More force = more power.
khanselman
Aug 25, 2006 12:40 PM
