ZC DOHC?
anyone know which car did this engine came from ZC DOHC motor.
RE: ZC DOHC?
it's a jdm motor. honda civics in japan came w/ these motors that was dohc non-vtec, years 88-95
RE: ZC DOHC?
which 5G cars were they in? i thought they only came from 4G JDM Civic and CRX Si's.
RE: ZC DOHC?
what kinda tranny do it use? and will bolt on to this zc DOHC engine?
RE: ZC DOHC?
ORIGINAL: Nail I3unny which 5G cars were they in? i thought they only came from 4G JDM Civic and CRX Si's. "After 1992 in some Civics and a few 1994 and up Integra’s still come with the odd model: the DOHC ZC. These ZCs look like the Civic style ZCs from 88-91 but have the later style electronics. There are even more Integra and Domani models with SOHC ZC engines. There is not a lot of interest in these (SOHC or DOHC) engines I am afraid, because the B-series VTEC motors bolt right in the 92 up Civics. The ZC does make a good swap in the lowly, underpowered CX or VX, but only with the EX, Si or ZC transmission, otherwise I don't recommend them. But for the sake of argument and to impress you with our large volume of trivial Honda knowledge, let's go ahead discuss them. To recognize thie 3rd generation DOHC ZC engine, just look for the black valve cover and 92 up grey colored electrical connectors. Some of the other visual clues are: * a plug in the end of the exhaust cam, like the B-series motors * two studs sticking up from the driver's side engine bracket poking out of the timing belt cover * and no writing on the top of the intake manifold, just the three raised bars on the casting like all the other 92-95 Civic engines. What do they fit? Well, they will fit the 92-2000 Civics or the 94 up Integra... not that anyone would want to put it in an Integra. Again, this engine bolts to the stock transmission and the Si or EX trannys make for a decent combo. But if you decide to use the 92 up ZC tranny with your 92 up ZC engine, get the 92 up Civic ZC intermediate shaft too because again, there is no US counterpart to this part. Although it is different from the 88-91 style, it is interchangeable." check for more info here |
