zc isn't starting..code 4 and 10
Well... its not starting..
dohc zc swap in my 88 std (DPFI) here are my symptoms.. I have ECU codes 10 and 4... i tried switching my distributor white wires...tried switching my CPS wires... I have spark in all four cylinders. The engine is cranking but wont start.. fuel seems to be injecting..i had a leaky injector but i got new orings all around..fixed the problem. http://youtube.com/watch?v=VqiWJU5qNOs it also has a little bit of a tick to it... any help would be appreciated [align=left] [/align] |
RE: zc isn't starting..code 4 and 10
What year Civic?
1988 with a dohc zc swap.
I don't think codes 4 and 10 would prevent the engine from starting.
Here are some potential causes for your starting problem: 1) Low fuel pressure and flow (pictures 1 and 2). 2) Engine timing way off. 3) A vacuum leak in a hose or connection (picture 3). 4) Problems with the throttle control system (pictures 4 and 5). http://img505.imageshack.us/img505/1...ure0257pv5.jpg http://img505.imageshack.us/img505/2...ure0258dp6.jpg http://img505.imageshack.us/img505/2...ure0259ty6.jpg http://img505.imageshack.us/img505/5...ure0255cg9.jpg http://img505.imageshack.us/img505/1...ure0256ks5.jpg |
alright..thanks ron..ill try these out tomorrow see if i can get it to start..
