2001 civic motor swap
OK so since a B- series engine wont fit because of the mounting problem what about the H22A and if not how much work is there involved in swaping out the d17a1 for a k20. I'd also like to know if you could get just as much HP out of the a2 version of the d17 motor as if i were to put in a k20 or at least close to it?
RE: 2001 civic motor swap
K20a2 swap would be easy... hp wise the K20 will already be over 2x the power of your d17... it would take ALOT to get the d to be near a k... I just watched PINKS! on speed channel and they had a k20 in a civic that claimed to be pushing over 400hp without spray!
ok ive decided to put in a k20 now which was the one i could put the turbo on it was the A3 wasnt it so as far as the swap goes what else am i going to need besides the motor and the tranny and the ecu and i know there was a thing somewhere that said it but i cant seem to find it again
im just learning about it myself. i think you forgot mounts but i dont know if you need that for that car and engine. best of luck to you, you are one lucky man if you get that K series in your civic....
- John B. |
does anyone read the stickies?
https://www.hondacivicforum.com/m_272469/tm.htm |
nvm misread the thread
