Smoked Tail Lights (Vinyl)
17 Attachment(s)
This thread will cover what you need to do to have smoked taillights
Okay, first things first. 1. vinyl not tint, not paint, transparent black vinyl works the best for the curves and edges of tail lights. most newer civics have complex curves in the taillights this will make your install much easier. Attachment 9900 orical makes a great product for this. 2. Tools, make sure you have the right tools to do this for optimal install, here is what i used for this project. i used a soap and water solution(2 drops of soap to 1 bottle of water (shake well)) along with denatured alcohol/water mix(i use a 70%alcohol to 30% water but you may want to have that switched if you have never done this before). Attachment 9901 3. Make sure you over size the piece you need to make sure you cover 4. Clean the area of debree, dust, etc.. any dust or dirt can be seen Attachment 9902 5. this car had the reverse lights in the same housing and the customer did not want them coverd so i used masking tape to cover the area that was not to be smoked. this also alows you to cut the vinyl to shape without cutting on the housing Attachment 9903 6.soak the area very well with your soap and water mix to insure you can slide your piece around for best placement, remove the vinyl from the wax paper, while spraying the sticky side with denatured alcohol Attachment 9904 7. apply the piece to the taillight and start application from the center out. smooth out the vinyl using a rubber squeegee(on far left of tools pic) Attachment 9905 8. heat..... well that is on a case by case bassis, i did not use any heat for this application but I have used it on other lights depends on the situation, just remember to go slow when using a heat gun i would rather take my time and heat it up slow then try to heat it really fast and burn the material. 9. use a razorblade to cut off access material, remember when you are cutting not to cut on the car but the space between the housing and the paint. also leave your self some room to tuck the vinyl in around the edges so you dont leave any edges exposed Attachment 9906 Attachment 9907 10.Remove all access material from work area Attachment 9908 Attachment 9909 11. tuck the edge in with your squeegee Attachment 9910 Attachment 9911 Here is a picture so show the difference between smoked and not Attachment 9912 12.completed tail light with cut out reverse light Attachment 9913 Attachment 9914 Attachment 9915 I think that covers it. if I missed anything or you have questions please let me know I will add to it. and for those of you who dont know the car it is sick:) Attachment 9916 Good Luck |
| All times are GMT -8. The time now is 11:52 PM. |
