PLZ help my 93 civic is getting 10 MPG!!!!
Have you checked the computer for trouble codes?
Does it idle normal once warmed up? They are designed to idle fast when first started.
If the engine is revving really high before the automatic goes to the next gear, even if you are only pressing the gas pedal lightly, there could be a problem with the cable from the throttle to the transmission.
Wrong timing (cam or spark) can make the mpg very low. That will not turn the CEL on. Also you should make sure that all 4 cylinders are working by disconnecting the fuel injectors one at a time. You do need a steady idle for that test.
