1995 civic
I couldn't remove the timing belt and exhaust manifold so I am not doing the head gasket, water pump and timing belt repalcement. Maybe I'll go to an auto shop and have them do it for me. I could not remove the bolts on the exhaust manifold. Five of them though all size twelve, are wierd shaped and won't budge.
So I end basically doing a tune up with new wires, spark plugs, changing the coolant, oil and oil filter. I am right now at the oil filter part.
Well I just join this forum and theres loads of great info.
I'm also on a anther forum called Civiclife.net.
It's a UK based site with over 7000 members in just a few years running. It's the busiest Civic based forum in the UK! Civiclife has evolved over the last few years to become not just civic based but any car based, aslong as your a nice person! We have Nissan's, Toyota's tbh anything you can think of, theres probs a member on Civiclife.
So why not join up, share your knowledge, and see what we do over the pond! You might be suprised at what we can do. We get to see some of the crazy stuff you do with cars!
www.civiclife.net
Hope to see you soon.
www.civiclife.net
Well, my tune up worded out ok and my car still starts. Yay! Now I am having an overheating problem. That happened before I did the tune up though. The car was getting hot the last time I drove it to before I started trying to fix it. What I realized today is that the radiator fan for some reason stop working. I have no idea why and I am guessing that it is the main cause of the overheating.
Edit; Heater control panel also doesn't work. Help!!
Can anyone give me a hint on how to fix this. My whole cooling and heating system is not working. My radiator fan does not come on and there don't seem to be any power to the heater control panel. Thanks
So I found this thread <a href="https://www.hondacivicforum.com/forum/showthread.php?p=630016">radiator fan not working</a> that explain my issue. I tested the fan and it does work. I've look at the fan relay under the hood box and it seen fine, so I am not sure if that's the problem. So what else do I need to check? Thermo sensor?
That's weird when my engine is non-vtec. thanks
